I have a house with a vivint system would I be able to incorporate my current system and monitor and control the automation functions through your services?
Hello from suretyDIY and Welcome to the Forum!
The ability to switch to suretyDIY would largely depend on your current panel.
If it is a 2GIG Go!Control, you would need to get a new Cellular Module as well as a firmware update to your panel. This kit here would get you started. For the LTE module in the kit as of 11/2019, firmware version 1.19 would be required for the module to work with the panel.
If it is the Sky panel, unfortunately, there is no Cellular Module that would work with Alarm.com. A new panel and cellular module would be required.
Here is a comparison of our service packages.
Many of the later Vivint gocontrol panels were running 1.9.6. If this is the firmware that is on the panel, a firmware update isnt required to switch out cell module and activate a new alarm.com plan on it.
