Do I have to cancel adt before install suretyhome
Will you be reusing your system? What kind of system do you currently have? ADT usually uses a propriety panel that isn’t allowed to be used with other companies but that isn’t always the case. If you currently have an alarm.com account, you will need to have ADT cancel the account so the cell can be unregistered when signing up with us.
About our service, we are a do it yourself, Alarm.com service provider. All service and support is handled online through our website, we are unable to provide phone support, local installation, or maintenance. You can find more about how Surety works here.
Service through Surety requires an Alarm.com compatible panel as well as an unregistered, 4G LTE cellular module. If you already have equipment, you can check the status of your cellular module via our Module Check Tool to determine if your system is eligible for service. If you aren’t sure which type of module you have, refer to this guide here.
Plan pricing and features can be found here. As service is offered on a month to month basis, plans can be changed at any time. To begin service, purcahse the service plan that best suits your needs. After purhcase, the website will walk you through the account creation process. Provided you have an unregistered, 4G LTE module, it takes about 5 minutes from service plan purhcase to account setup and connection.
Here you will find our General Policies and Frequently Asked Questions! Technical support can be found on our Support Site , where our technicians are always happy to help you!
