We just added Surety Home without monitoring, and are wondering if Surety Automation would be a better fit for us.
If we switch to Surety Automate, would we be able to change the setup so we get reports/notifications on the smoke detector and water/flood sensors?
I saw this: “If you program it as a door sensor under Sensor Group 25, it will only be used for notifications (no alarms will occur locally), and we can manually select it as a water sensor for you in Alarm.com, allowing you to use the ADC water management features with it.”
So it sounds like this may be an option for us.
