I’m looking to add a simple Zwave water sensor into our SImon XTI5 that will report to unit (non alarming not notification, I believe group 25 or 40 what I had seen on here). I know the Qolsys QS5536-840 will work, but will any Zwave sensor work that operates on the correct frequency work, then just setup an alert in alarm.com?
I.e. something like the Ecolink Zwave Plus Flood & Freeze Sensor or any other zwave sensor
TYIA
To clarify, Z-Wave Sensors are not Alarm.com compatible. Only Z-Wave devices such as Lights, Locks, and Thermostats will work.
If you need a water sensor, a 319.5MHz water sensor like the QS5536-840 could be used.
Thank you Tyler, I appreciate your prompt response as always
