pause on your research on this. I dont think you can use the Nutone intercom transformer even though it shows 11 V. I am going to hardwire with AC transformer and will let you know
I read every install manual but dont see my scenario.
How do you wire with the DC adapter (the one you buy as an accessory to the ADC doorbell that plugs into the wall) and a wired doorbell chime? Do you have to still use resistors
I only see the example with the AC transformer and chime
You wouldn’t.
Chimes typically require an AC transformer. If you are using the wired chime you linked here, it needs a 16VAC transformer.
