Status Light for Multiple doors
Hi mikey,
Which model of the Inovelli did you go with? Did you use the simple on/off switch series or the dimmer switch? I am looking at the dimmer model as it has a much larger led light. Not sure if the small led light on their on/off switches would be noticeable enough. Let me know which you went with and post any picture if you can. Looking to do the same with my setup.
Thanks
I went with the Red On/Offs. Basically because the Red Dimmers appear to be on backorder. I have one I will probably change when it becomes available. They are plenty bright. You can also set the light to blink if you want. If the switch is in the field of vision, it will be noticeable. Certainly as noticeable as the old Vista panel we are used to…:
Multi-channel Z-Wave relays should work now in Alarm.com, if you’d like to give it a try.
