Spacer for PG9303 sensor?
Is there a spacer available for a PG9303 sensor? I need to mount mine on a door frame that is higher than the door, and the magnet and sensor won’t align vertically without a spacer under the magnet.
I had the same issue awhile back. Honeywell makes Spacers that solved my problem. Their product number for 4 Magnets & Spacers is No. 5899B.
There aren’t any spacers made specifically for the PG9303, but you can make one or use something else as the user above suggested.
