I’ve been using Sonos with alarm.com and it no longer shows up in the app. I tried disabling audio on my account and re-enabled it but there is still no option for audio. Did alarm.com remove this integration?
Sonos is supported. If you disabled Audio and re-enabled you would need to relink your devices, you should be able to view that option based on what I see on your account.
If you login to the Alarm.com website (instead of the app) and go to Settings > Manage Devices > Add Device > Audio, are you able to view the setup process?
That fixed it. Thanks for the quick response
