Somfy Shade Support
Hi All - I have an outdoor shade that is powered by a Somfy RTS motor. I found the article from late last year that Somfy is now supported w/in ADC. (Via back-end connection).
Does anyone know if ADC integration -only- works when you have the Somfy Tahoma Hub or will it also work with the Somfy ‘mylink’ device?
Tahoma Hub: Somfy TaHoma - Join the smart shading evolution
MyLink: Somfy's myLink: Home automation for all your window coverings
Thanks!
-Ryan
Only the TaHoma hub is listed as compatible at this time.
