Hi.
I’m trying to find the number to call when I have an active break in but didn’t arm the alarm. Please advise
Hi.
That’s when you call 911.
As for the Surety monitoring center numbers…
The user above is correct.
If you’re having an emergency and you’re able to make a call safely, it is always recommended to call 911 or your local emergency number directly rather than using your system or the monitoring center.
This ensures your call will be prioritized, and you can give critical information directly to emergency responders.
