I pushed the power button on the side for 30 seconds, now the light is flashing green and red, no image on the panel, not able to access. Any guidance would be apprecited
In a state where you cannot access the panel menu, the only real troubleshooting will be via power cycling. I can confirm that the system is not currently responding. I would try an extended power down.
Unplug the transformer from the outlet and then open and unplug the battery. Wait at least 5 minutes, then try powering it up and turning it on. Any change?
Were you making any changes to your system when this happened or did the error just occur overnight?
Last thing to try here is a Hard Reboot. With the panel powered up, hold the button on the side down for 30 seconds then let go. The panel should reboot afterwards. Does it?
Ok, The panel is under warranty so we will get the warranty process started. We will follow up with additional information by email. In the meantime you can find our return policy here.
