I have a few smoke detectors that keep going offline. I changed out the batteries and the units are still good date-wise. They’ll work for a little bit then the main panel starts beeping and says “failure.”
Is there anything I can try?
Thanks
Thanks
I am adding a general guide to offline malfunctions below, which describes a variety of common causes across all sensor types.
Smoke Detectors, depending on the model, often have different possible causes as well beyond the ones described in the guide.
What model of smoke detector do you have, and how many seconds between flashes of its LED currently? Is it beeping?
Thanks for the response.
It’s an Interlogix SDX-135Z. This model does not flash any lights.
Is there anything I can do to fix it. It seems that it was working for years and isn’t even the furthest one away from the panel.
That model SDX-135Z was discontinued in 2019 I believe, and have a 10 year lifespan from manufacture date, not date when they were put in service. Just to verify 100%, what is the manufacture date on the smoke detectors?
Recurring offline troubles would not be resolvable if expired.
If expiration is definitely not the issue, confirmed by the manufacture date on the unit, then if you have any closer to the panel which are not experiencing this issue, try swapping the locations of a working one with a problematic one. Does the problem follow the detector or does it resolve?
This can help identify environmental or range issues if present.
