Does the system need to be placed in test mode prior to testing a smoke detector via the test button on the device?
Yes, you should put your professional monitoring account in test mode before you use the test button on the device. For some brands it takes about 30 seconds of holding down the test button before it will send an alarm signal to the panel but you probably want the account in test mode before that happens to avoid an accidental fire truck at your house.
