Does anyone know the size of the magnet for the 2GIG-DW40-345? I’m trying to put the magnet part on the top sash of a double hung window. I have just under 3/8 of an inch to work with.
Were you successful in using a smaller magnet for this sensor? Where do you buy this?
I just tried installing the DW40-345 magnet on a new slider window. It’s too large, specifically due to the depth it hits the sliding window.
Preferably the dimensions would be under 10mm wide and 5 mm deep, height does not matter.
Also, I’m used to double hung installs, this is my first slider. Besides the obvious (vertical install) is there anything else I should consider with the sensor placement?
The nanomax uses the thinnest and lowest profile magnets I’ve seen packaged with a wireless sensor. It is the best bet for double hung windows or other tight spots.
