When I upgraded to the Qolsys Panel 4, I found that there was no wire connection for my external siren/strobe device. Is there someway I can drive the siren/strobe from the panel?
What system were you using before? Do you have an IQ Hardwire takeover module?
Qolsys 2+
I see the problem. You had the Siren/Strobe connected to the back of the IQ Panel 2 and the new IQ Panel 4 does not have the terminals in the back of the panel correct?
Unfortunately, you cannot use the panel like the IQ Panel 2 and would need another device to get this to work.
You can use an IQ Hardwire PowerG as this has a siren output and PGM outputs.
There is the PGP-IO9 which can also be used to trigger the siren with a separate power supply but we currently don’t have it on our store.
Thats good news. Thank you!!
