I have several Qs1135-840 installed along with the IQ panel 4, but the farther away I put them from the panel, the less they work. Is there a signal extender for these?
You can use an RE524X to repeat the signal, but the QS1135 would need to be programmed as a standard Security RF 319 in the panel, not S-Line, in order for it to work with the repeater.
It is generally recommended to instead use PowerG sensors for more distant locations, given their roughly 4x range over 319.5Mhz sensors.
Thank you! Can you tell me what PowerG sensor would work best for windows with the IQ Panel 4?
