I need to spend $110 to buy a 4G communication panel for my older Simon XT. It’s probably 6 to 10 years old I’m guessing.
I’m wondering if I should consider upgrading to a newer system instead of spending $110 on an old system.
It’s a very basic setup with just Doors/Motions/Glass Break sensors and that’s all I need. No other controls needed, or any other fancy features. No need to remote program.
Should I upgrade to a newer system just for the sake of it due to system age?
Or will the Simon XT likely continue for many years of reliable service?
What is the least expensive option, perhaps one that could use the same sensors I already own. I see from an old post that the GE sensors should work with Qolsys ( 2014 post)
It’s a secured remote location 10 hours away. If it were to fail would be a costly problem involving missing 3 or 4 days of work to repair. The Simon XT has been reliable, so I would not want something that occasionally needs to be rebooted, or anything like that, because I’m not there most of the time and could end up with a non communicating system. Remote access needed for arm/disarm, but not remote programming.
Is there any reason to upgrade to an XTi, i5, 2gig, Qolsys, or any other?
XTi is easier to program, but don’t really need the added features I’ve seen, same for 2gig, etc.
Not using any home automation.
I do like to run the XT on a 12 Amp-hour battery, with longer leads to the external battery.
That way if someone shuts off the power for a week or more, the alarm will still be active.
The only consideration that comes to mind is during an alarm at a remote location the Simon XT sirens alarm for 5 minutes, then stops siren until another alarm is triggered.
Maybe if I could let it the alarm continue until it’s manually deactivated that might be a plus, though I’m not sure because if it had a false alarm and I could not be reached, neighbors might flip. I also plan to hook up 2 wired sirens. I did that with the XT.
That may not be as important as other features.
If the Simon XT is known to be a workhorse that will last for many years I will consider just upgrading the comm to 4G.
Thank You!
