I’ve got a Kwikset Z-wave deadbolt on my front door that has been learned in to my panel already.
I’d like to set up rules so that it automatically locks when I arm the system, and so that the system automatically disarms when I unlock the deadbolt. How do I do this?
BTW, the SuretyCAM yard signs went up today, and the Vivint yard signs went in the trash. Yay!
I would discourage having the Kwikset deadbolt disarm your alarm, unless Kwikset changed their lock significantly since I got mine. Ultimately you are placing a lot of trust in a device that is 1 couple of buttons away from anyone setting their own code. The problem with the Kwikset is you just have to slide open the cover, hit the button to learn a new code…key in a code and its accepted. No security, meaning a door-to-door solicitor that you invite in, a guest, or anyone could do this pretty quickly if your back is turned even for a few seconds…and its an easy lock to identify from the outside. So now you ultimately allowed someone to self program their own access to disarm your alarm.
I have one of these locks, but it still requires the alarm to be disarmed independently due to this design flaw. There are other brands that require a master code to add new codes.
I would discourage having the Kwikset deadbolt disarm your alarm, unless Kwikset changed their lock significantly since I got mine...There are other brands that require a master code to add new codes
I know this is old, but for those who may stumble across it, I thought I would update.
910 Kwikset can be programmed for a master code that must be entered to add/delete a user code. There is also a secured cover that uses special rounded screws to prevent anyone from just opening it up on the backside (you would have to smash/break it).
