So far I have seen all of the thermostat options except the fan circulate. The rest of the advance setting etc are on my phone app. Thats why I didn’t even look on the Website.
Understandable. Typically, one touch control options will be identical (and this function specifically will likely be added in future updates).
The mobile apps are limited, and are lacking many features and functions. For example (last time I checked), You cannot delete Image Sensor gallery items from app, You cannot Configure a Video Camera VMD window, you cannot select Tstat circulation fan mode, there are limitations to rule creation, etc
Well I only have the thermostat and that’s why I never knew about the circulate setting. I had it configured in the app because it would let me do it. And the text baloons in the app never explained any of this.
I just expected the features to actually work since I could adjust them.
it is a good way to ruin your HVAC. I don’t use auto mode for that reason (I also have a heat pump), and setting HEAT/COOL that close is just asking for trouble.
Agreed. Keep in mind your “Overshoot” and “Swing” values may be numerically expecting heat beyond your cool threshold and vice-versa if you do this.
