Panel is showing a tamper signal from a sensor once or twice a day for a week, how do I fix this?
Happy to assist! Records indicate that the sensors in question may be a Resolution Products RE111 door window contact, is that correct?
In this case, the RE111 does not actually have a tamper switch internally. Those sensors will throw a tamper alert when the internal battery is getting low. You will want to replace the battery on the offending sensors. The battery is a CR1632.
