Sensor Range Extender - IQ Panel 2 + Verizon
Is there a way to extend the range of my sensors? I just moved to a bigger house (3,400 sf) and I have a couple of door security sensors not picking up. I have the controller brain sitting in the middle of the house.
I have the IQ Panel 2 + 319.5 mhz Verizon with QOLSYS TX-1012-01-1 WIRELESS DW CONTACT TRANSMITTERS
Thanks
You could get a wireless repeater like this
Or you could replace those sensors with PowerG sensors which have a much longer range. That’s assuming your panel supports PowerG sensors. Which model panel do you have?
Replacing with PowerG would be the more reliable solution.
I have the IQ 2 + Verizon 319.5mhz
Can I use both Power G in conjunction with my current 319.5 mhz sensor simultaneously?
Yes you can. :grinning:
