I need to get several systems soon, and the easiest thing to do is get Interlogix equipment, but I just can’t get my head around this encryption thing. You say the GE/Interlogix sensors are encrypted because they use the 319.5mhz band, but I don’t understand how that makes the transmission encrypted. Digging very hard, I have come up with these models being encrypted & spread spectrum based on their manufacturers published advertising:
- Honeywell Lyric with SixSeries sensors
- Elk M1 with Elk 2-way sensors
- DSC Neo with PowerG sensors
On the contrary, I find nothing regarding there being any advanced technology used with GE sensors, and this is published on every GE/Interlogix wireless 319.5mhz product installation sheet:
NTERLOGIX DOES NOT ENCRYPT COMMUNICATIONS BETWEEN ITS ALARM OR SECURITY PANELS AND THEIR OUTPUTS/INPUTS INCLUDING, BUT NOT LIMITED TO, SENSORS OR DETECTORS UNLESS REQUIRED BY APPLICABLE LAW. AS A RESULT THESE COMMUNICATIONS MAY BE INTERCEPTED AND COULD BE USED TO CIRCUMVENT YOUR ALARM/SECURITY SYSTEM.
What am I missing? I was ready to go with Interlogix, but based on this they are out and I would need to go with Elk M1 or DSC Neo.
