Schlage Z-Wave Deadbolt Lock issues
Also, check the number of digits your Schlage lock is set to use. Because of the way Schlage’s values are set, ADC can only support 4 digit codes. If you have the lock programmed to use other lengths syncing will always fail.
See here for more info.
