Hello. I wanted to see if there was any word on if and/or when the new Schlage Sense Pro door lock will be compatible with alarm.com. I know it took a while for the Schlage Encode Plus to be adopted and I’m hoping that won’t be the case for the Sense Pro.
I’ve not heard anything from Alarm.com about this lock, however I am happy to reach out and see if they have any info or plans to integrate. I just sent Alarm.com a message and I will follow up here with any info I can get.
Great, thank you so much!
Just circling back on this, support for this new lock is indeed on the roadmap, but I am guessing it likely won’t be until the new lock model has a wider user base, so it may take a little time.
Jason,
Thank you for following up on this! It’s good that it is in their roadmap. I only hopes it happens sooner rather than later! ![]()
Schlage WiFi was horrible for me. Do a search and I documented. Went back to zwave Schlage locks and they have been trouble free
Interesting. I haven’t had a single issue with mine since I installed it.
