Hello , occasionally some of my s line sensors report still open occasionally they are actually closed. I noticed it happens usually if the door is left open for a few minutes, then it’s closed. In other order to clear it I must open and close the door again .Is this a known issue with these sensors? Would switching to power g sensors remedy this?
Thank You
It is not a known issue I am aware of, but it strikes me as potentially a signal concern based on your description. Are those sensors farther from the panel or near metal? The activity you describe sounds like a borderline low signal situation.
Power G has a much farther range and should provide better signaling if that is the cause.
