“I have hardwired interconnected smoke/CO already — what’s the cheapest way to get them monitored through surety, without replacing all of them?”
With 319.5Mhz, you are able to add the firefighter which will monitor your current 110VAC smoke detectors.
There is no option like this for 319.5Mhz and CO detectors. You can use a wireless IQ or PowerG CO detector if needed.
Thank you for the valuable feedback
"I’m considering an Interlogix FireFighter SLX-AD-T3 audio listener (319.5 MHz) to monitor my existing hardwired interconnected smoke detectors instead of replacing them — does my IQ Panel 5 support 319.5 MHz, or is there a PowerG-compatible equivalent?
Your panel currently reports having a 319.5Mhz daughtercard, so the SLX-AD-T3 should work fine for you.
There is no PowerG equivalent to the Firefighter at this time.
Thank you for your advise. Really appreciate it.
