Hello - I added 5 Nest thermostats on my ADC account but would like to remove them. Just to confirm, it seems I can only control on/off, heat/cool/auto mode and target temperature from ADC, and am not able to program automation (e.g., turn a/c off when doors open), is that correct?
Thank you as always and please let me know when the Nest tstats are removed.
Surety Team,
I am planning to replace my Thermostats and wanted to see if Nest is activated by Admin on the back end, I will be able to add it to my ADC account? I heard there was a period of time that integration was disrupted but wanted to make sure that has been restored.
The one I am planning to get is Nest Learning Thermostat.
You can manage Nest support in your plan in the system manager, and you can then add a Nest thermostat in the Alarm.com website. There is no current issue with adding them.
