Remove Garage Door Opener and Thermostat
Could you please remove the garage door opener on my system? I have 3 issues showing. All three are associated with these devices I no longer have installed and need to remove from the system.
Thanks!
Your title references the thermostat too, would you like that deleted?
Keep in mind these are both Z-wave devices and remote deletion commands will only work if the device is powered off and cannot communicate at all with the panel.
I sent a command to delete the garage, allow a few minutes for that
Sorry. Completely forgot to follow up on this issue. Yes, the thermostat can be deleted as well. Both devices (garage door opener and thermostat) have been removed and replaced. The garage door opener is still showing on my Alarm.com app.
I sent commands for both of those. Please allow 5-10 minutes for that to take effect.
