Can the IQ Lock pg be rekeyed? I am considering installing multiple locks and would like to have one backup key that would open all of them.
The PowerG IQ Lock uses a Kwikset KW1 keyway, so it should be able to be rekeyed by disassembling, pulling the keyway, and replacing the pins using a Kwikset pins kit. A locksmith can do this easily, or if you have a kwikset re-key locksmith kit you could DIY it. I recommend some caution though, it can be a bit frustrating and it’s easy to lose/misplace the springs if you haven’t keyed a lock before.
Thank you.
