Hi, all,
Going to be moving into a new place soon, and I’m looking into getting a home security system set up there. I’d like 24/7 security, fire, and medical monitoring.
Some details on the house:
Square Footage: 1250Sqft across a single story.
** Doors:** 2 Wooden Doors (Front Door, Garage => House Door) and 1 Sliding Glass Door; I’d like all of these to be monitored. There’s also a garage door, but I think that should be well protected on its own once we install a LiftMaster system?
** Windows:** 4 Windows; I’d like all of these to be monitored. Each window is in a separate room.
Leak Spots: 7. Fridge, Washer, 4 sinks, and Water Heater.
Wiring: The house is not currently wired up for security systems. However, there is a box in the garage already where the security system wires could terminate.
At this point, I’m heavily leaning towards getting a system with Surety. I don’t think the DIY would be too much to navigate, at least as long as I’m not going to have to hardwire anything–which doesn’t seem to be the case with Surety.
As of right now, I’m thinking I’ll go for the following system setup with Surety Home ($22/month):
- Essential Equipment (1x Qolsys IQ Panel 2+, 2x IQ Mini Door/Window Sensors, 1x Month of Surety Monitoring)
- 5x Mini Door/Window Sensors (is it worth getting the embedded ones?)
- 1x E-Series FireFighter Encrypted Wired Smoke Alarm Audio Detector (The cart says this isn’t compatible with the IQ system; what alarm detector is compatible with the IQ system?)
- 7x IQ Flood Detectors
How does that system look? Any other protection y’all would recommend?
The flood protection is pretty bloody expensive ($343), but a leak could of course be far pricier. Have folks had good experiences using an alternative leak detection system?
I’ve heard that the 2GIG Edge panel is a good competitor to the IQ panel. Does the IQ panel have any advantages over the 2GIG panel? What about Honeywell, DSC, and other system manufacturers?
Any other thoughts or recommendations?
Please let me know if you have any thoughts or questions!
Thanks!
