Hi. I’m Looking to purchase a few PIR motions sensors for a home with a 50lb dog. Considering RE210P or Honeywell 5800PIR-RES. Can any one recommend one of these over the other?
The Honeywell 5800 series seems to have a fairly good track record online.
I can’t find much about the RE210P.
The RE210P has a slightly larger stated range and an operating temperature that dips below that of the 5800 (though it’s an indoor Motion so the 14 degree minimum for the 5800 should probably suffice).
They are very very similar products.
One other difference is the RE210P has a wired contact input to act as a transmitter for a hardwired zone.
