Using the keypad, how do you restart/reboot a 2GIG panel?
If you have a surety account, the easiest option would be to log into your account. Click the system manager link. On the next page a button should appear that says reboot panel. The only other way to do it without removing all of the programmed devices would be to unplug the wall power and take the panel off of the wall and unplug the red and black wire going to the green battery pack for at least 30 seconds. Then plug it all back in and re-secure the panel to the wall. I highly recommend just doing it through the system manager to save yourself a lot of time and effort.
If you are using the GC2 panel, not the GC3, you can also go into system configuration, then exit, saving changes without having made any edits. This will reboot the panel.
There is otherwise no manual reboot option in the panel UI. You can always send a remote reboot command through your system manager as suggested above.
