Hi, I would like to know how I can disable completely quick exit while is the system is on stay? I cannot find setting to disable/enable it. Thanks
Quick exit cannot be disabled on the panel. The only thing that can be disabled is the Exit beeps. I did get this confirmed with Qolsys.
Vidail, let me disagree with you and Qolsys to some point. I went through all the setting and was able to disable Quick Exit on stay somehow. I cannot exactly remember what I turned off, but as of now I have no quick exit on stay .
Could it be possible you enabled En Grade 2? I was testing some features and this turns off the Quick exit however there are more changed that occur on the panel.
You are right!!! En grade 2 is enabled. Probably I checked it on by mistake . I heard that it is some Europe standard.
Should I keep it on or it is better to turn it off?
Thanks.
More info on it can be found on page 191 of the manual however not all changed to the panel are listed under there. One change not listed is that Quick exit is disabled.
We are currently trying to get a list from Qolsys of all the changes but so far they have only directed us to the installation manual. I will give you an update if they provide something with more details.
As if you should keep it enabled is up to you if you are okay with the changes it has.
