I have the Qolsys panel and I am try to add another TX-1012-01-1 window/door sensor to a back room. It does not seem to communicate to the panel at the back room but does inside the house, so I assume the distance is playing a factor in this. Would the Resolution Products Universal Repeater, Translator (RE524X) help in the situation? The distance is about 75-100 feet from inside the house to the back room? Works with Qolsys?
Yes, the RE524X is a universal repeater/translator that is compatible with GE and the best solution for range issues.
As a GE repeater, you would use the selection dials to set the 524X to look for GE sensor signals and repeat them to a GE panel.
