Qolsys IQ Pro Firmware Release Information
IQ PRO - 4.2.2n SOFTWARE UPDATE - RELEASE NOTES AND INSTRUCTIONS
TSB #: 230710
DATE: 07/10/23
New Features:
  • Added Key Switch option, when utilizing sensor type Keyfob on these devices: IQ Pro, HSM2108, IQ Hardwire PowerG or PowerG sensors that support auxiliary inputs.
  • Enhanced support added for the Power Series Neo Touchscreen (HS2TCHP). The HS2TCHP will require a SD Card update in order to support.
  • Support added for the new MX975i - universal input addressable device using NC loops.
  • The IQ Installer Interface will now prompt to connect to the IQ Wi-Fi6 security SSID when utilizing IQ WiFi6 allowing seamless local programming.
Update Instructions:
Compatibility Note: Your IQ Pro must be on software version 4.2.1n or higher and connected to Wi-Fi or Ethernet to install this update.
  1. Connect to IQ Pro utilizing the IQ Installer Interface
  2. Touch “Configuration”
  3. Touch “Upgrade Software”
  4. Touch “Patch Tag” and enter the patch iqpro4.2.2n
  5. Touch “Yes, I want to upgrade” (panel must be connected to Wi-Fi or Ethernet). Update will download and install
  6. The update process will take approximately 5 minutes. After the panel reboots reconnect the IQ Installer Interface
IQ PRO - 4.2.3n SOFTWARE UPDATE - RELEASE NOTES AND INSTRUCTIONS
TSB #: 230905
DATE: 09/05/23
New Features:
  • Corrected an issue where in certain scenarios wired motion sensors did not show open on the keypad.
  4. Touch “Patch Tag” and enter the patch iqpro4.2.3n
IQ PRO - 4.3.0n SOFTWARE UPDATE - RELEASE NOTES AND INSTRUCTIONS
TSB #: 240411
DATE: 04/11/24
New Features:
  • Added support for PowerG Home Automation.
  • Added support for the PowerG+ Devices.
    • PGP9945 - Door/Window Contact with External Input.
    • PGP9303 - Vanishing Door/Window Contact.
    • PGP9914 - Flat PIR Motion Detector.
    • PGP9922 - Glass Break Detector.
    • PGP9920 – Repeater.
  • Added support for Proximity Tags –easily arm/disarm with a tag on supported keypads.
  • Added support for Force Arm – allowing auto-bypassed zones to be reactivated if closed while armed.
  • Added support for Manual selection of Z-Wave Frequency Region.
  • Added new Key Switch Arm and Disarm Only option.
  • Added support for the new PGHPHOST9 PowerG Host+
  • Added New PGM Rule options.
    • Zone Follower now supports all sensor types.
    • Bypass rules.
    • Troubles rule.
    • Burglary Confirmed rule.
  • Added support for Global EOL Input selection.
  • An Active IQ Installer connection will now Inhibit Arming during Local Programming.
  • EU External Bell – Bell Output can be configured for EU external bell compatibility.
  • Added support for the IQ Keypad – PowerG keypad.
  • Added support for Anti-Masking Trouble – for PowerG devices that support anti masking.
  • Added a new Cross Zoning feature – which requires two or more zones to activate before generating an alarm condition.
  • Added Non-bypassable Zone attributes – Individual zones can now be programmed to not allow bypassing.
  • Temperature Display on LCD Keypads – LCD and TCH keypads can now display indoor and outdoor temperature based on PowerG device temp reporting.
  • Added support for Alarm.com Flex I/O sensors.
Fixes/Improvements:
  • Arming from Alarm.com will now fail if a zone is open or in trouble and auto bypass is disabled or force bypass is not selected.
  • Corrected an issue with the HS2TCH keypads where in certain cases the Fire, Ambulance and Police, Options and Outputs buttons are greyed out on power up
  4. Touch “Patch Tag” and enter the patch iqpro4.3.0n
IQ PRO - 4.4.1n SOFTWARE UPDATE - RELEASE NOTES & INSTRUCTIONS
TSB #: 260429
DATE: 04/29/26
New Features:
  • Support for the HSM3204CX (Corbus Extender) has been added.
  • New commercial sensor groups have been introduced, including:
    • Group 18: 24Hr Bell/Buzzer
    • Group 23: 24Hr Supervisory
    • Group 24: 24Hr Supervisory Buzzer
    • Group 27: 24Hr Fire Supervisory
    • Group 40: 24Hr Gas
    • Group 48: 24Hr Sprinkler
  • Manual enrollment for MX devices is now supported.
  • Remote diagnostics for Corbus modules are available.
  • Remote enrollment for Prox tags has been implemented.
  • PowerG+ sensor dealer lockdown capabilities have been added.
  • Native support for the following PowerG+ devices is included:
    • PowerG+ IOG Module (PG ID 530 and 106)
    • PowerG+ Indoor PIR Camera (PG ID 145)
    • PowerG+ Smoke/Heat Detector (PG ID 205)
    • PowerG+ Water Tile (PG ID 242)
    • IQ Lock PG (PG ID 502)
    • IQ Light and IQ Dimmer (3-Way)
    • IQ IDP (UK W-Way)
  • Remote over-the-air (OTA) support for Z-Wave devices has been added.
  • Battery gauge reporting for PowerG+ devices is now available on the Alarm.com Partner Portal.
  • A new jam state for water valves on specific Z-Wave shut-off valves has been introduced.
  • Programming options now include the ability to disable the tamper feature on IQ Hardwire PowerG (PGxWLSHW8/PGxHRDW8) and PGP-IOx modules.
Fixes/Improvements:
  • Fixed an issue where the IQ Installer App could intermittently fail to connect to the IQ Pro panel.
  • Corrected an issue where Firmware updates for the HSM3105MX Module were not applying.
  • Various system enhancements and fixes have been applied.
  • Cybersecurity measures have been updated.
Compatibility Note: Your IQ Pro must be on software version 4.3.0n or higher and connected to Wi-Fi or Ethernet to install this update.
1- Connect to IQ Pro utilizing the IQ Installer Interface
2- Touch “Configuration”
3- Touch “Upgrade Software”
4- Touch “Patch Tag” and enter the patch iqpro4.4.1n
5- Touch “Yes, I want to upgrade” (panel must be connected to Wi-Fi or Ethernet). Update will download and
install
6- The update process will take approximately 5 minutes. After the panel reboots reconnect the IQ Installer
Interface
