Is there a module that provides dry contact relay outputs that will Interface with the Qolsys 2+? I can only find input modules.
To best assist we would need to know the general application. There is no plug-and-play product that will read sensor/alarm information from the panel and trip relays, but there is always the option of tripping a relay via a Z-wave switch and automation rules.
The panel has a Siren relay which is a dry relay, but is not programmable, and only supports specific power limits.
I am looking to provide intelligent garage door control with a relay output that shorts the opener contacts on command an IQ door sensor that detects the garage door being closed and a IQ tilt sensor that detects if the garage door is open. I have done this in the past with an Elk panel.
Not 100% sure what rules you would have had set up, but there isn’t a need to rig something like that via relays and extra sensors.
Alarm.com has compatible garage automation options. Using a MyQ universal hub might be an option depending on the garage opener, or the GD00Z (an S0 version like the GD00Z-5 would be needed for the current IQ Panel 2+ firmware)
What model of opener do you have?
I have a generic Linear opener. I am looking for the following features:
- Door open / close capability from Qolsys panel and Qolsys keyfob.
- Door open / close not available when the alarm panel is armed. I shouldn’t be able to open the door when the system is armed.
- Panel shows whether door is open or closed.
- Warning/beep on panel when door has been opened for longer than 15 minutes.
Either MyQ or Linear Z-wave option would be controllable from the IQ Panel 2+. Neither from a keyfob.
This is not an option.
Either MyQ or Linear Z-wave option would be visible on IQ Panel 2+.
This is not an option, however you can set up Alarm.com notifications for that same effect, if the door has been left open for a specified time length.
Genie offers the Aladdin Connect. Which shows alarm.com support. Does the Qolsys panel have any interoperability with it?
Aladdin Connect®Smartphone Enabled Garage Door Controller – The Genie Company
Can the extra buttons on the Qolsys IQ-Fob-S be used to control the Qolsys IQ Outlet?
Genie Aladdin Connect can be linked to ADC but it would not be visible or controllable on the panel.
No, the Fob cannot control Z-wave devices.
