Does anyone have a suggestion for No-Neutral-Wire Z-wave Dimmer switch compatible with Qolsys IQ Panel 4? Needs to be able to dim LED lights.
I see a No-Neutral-Wire Lurton Zwave Dimmer (Caseta), but is unclear if it will be compatible with QolSys panel. Are all Zwave devices compatible?
The Inovelli LZW31-SN does not require a neutral wire. You can find a list of compatible devices with Alarm.com here.
FYI Lutron Caseta is a self-contained Lutron wireless lighting system. It does not use Z-wave or get paired with the panel. Caseta is supported on Alarm.com accounts with lighting automation.
