Qolsys 16-F and Resistors
Is there a recommended way to attach the resistors to the included sensors? I could probably solder them, but I think it will be difficult to get my soldering iron to the existing box. Is there a recommended crimp connector to use?
Yes, we typically recommend using a B-wire connector that you would crimp (can do so with pliers.) This is a good option. These can also usually be found in hardware stores.
Soldering wouldn’t be recommended generally in this case.
Great. Perfect. Thanks!
