Hello, does q13 in programming still only apply to 2 way voice over POTS? , If this is not the case then what would , or should the ideal setting be 1. Stay online, or 2. Stay online for burglary/Fire/Co ?
On the off chance of any future changes it should be set at (2) Stay online including fire/Co.
However, this programming currently does not apply to ADC two-way. Alarm.com overrides it when 2-way is enabled as a service. The dealer settings determine whether 2-way calls occur through Alarm.com. This is likely done because panel settings do not route signals to any particular CS, Alarm.com back-end settings route signals to the CS.
