How many Power G Repeaters can you put onto one QOLSYS IQPANEL 4 panel?
Typically a repeater is not needed due to PowerG’s long range, however a PowerG signal can only be repeated once and only one repeater should be used.
You can have up to 8 PG9920 (PowerG repeaters) paired to a Qolsys panel. But like Jason was saying you can’t repeater another repeater. So you can’t go panel → repeater → repeater → transmitter/sensor. But you can go panel → repeater → transmitter/sensor.
