"PowerG Card Communication Failed" Error when adding Door/window sensors
I am trying to add PG9303 Door/Window sensors to my IQ4 panel.
If I try to add by scanning the QR code, I get “PowerG Card Communication Failed - Please Check PowerG Card (Error Code #-1)”.
If I try to add manually, PowerG doesn’t appear in the Source options, so I can’t add the correct 7 digit DL ID.
Can someone tell me how to check the card?
On our end your panel does report only a 319.5Mhz daughtercard installed. (in addition to Z-wave radio). No PowerG card is detected and reported by the panel on our end.
If you navigate to Settings > Advanced Settings > System Tests > Daughter card Test. PowerG card should be an option if one is installed.
Can you send a private message here with a photo of the inside of the back of that panel?
will do
