Are DSC Power G motion detectors compatible with IQ2 panels?
If you have the IQ Panel 2 PLUS then PowerG would be usable.
You can use the following DSC Power G Motions:
-PIR Detector PG9904
-Curtain PIR Detector PG9924
-Mirror Optic PIR Detector PG9974
-360 Degree Ceiling-Mount PIR PG9862
-Outdoor PIR Detector PG9994
Great!
The product compatibility page says Sensitivity Setting Not Supported / FW 4.0.0 or Higher Required for the PG9914. Does that refer to the firmware for the 9914, and if so is it upgradable to support sensitivity? How does the 9914 compare to the 9904? Is the 9904 still available?
Also how do you recommend choosing between the 9914 and the 9984, 9904, and 9974? I don’t need pet immunity.
This refers to motion sensor software, not the IQ Panel 2+. Sensitivity settings cannot be changed when being used by the Qolsys IQ Panel 2+.
The 9914 offers improved battery life as well as improved motion detection.
While you may be able to find some 9904 units online, it was replaced with the 9914 by DSC.
- The PG9914 is a PIR motion, and has the best pet immunity (up to 85 lbs)
- The PG9974 is Mirror Optic PIR - Making it more sensitive over the 9914.
- The PG9984 is Mirror Optic PIR and Microwave- boasts more accuracy over the 9974 while retaining that higher sensitivity.
- Coverage area is better on the 9974 and 9984 (49ft) over the 9914 (39 ft.)
- Pet Immunity is best on the 9914, the 74 and 84 do offer it, but for smaller animals (up to 40 lbs).
- All 3 offer 6-8 years on battery life
Overall, the 9984 is going to offer the best detection and range but is not as pet friendly. As pet immunity is not a factor here, then the 9984 would arguably be the best of the 3.
