Possibly bricked 2GIG GC2 panel
Don’t see my original post so sorry if this is a repost…
Any help would be appreciated. I inherited a 2GIG GC2 panel, TS1, and numerous sensors from my folks. I also just bought a Schlage lock to hook up to it. I decided to update the firmware because it was at least a few years old and the alarm provider my parents used refused to update the firmware without a truck roll and charge (even though they had service over three years and I still pay them now). I definitely want to switch to SuretyDIY.
I thought I could be technical and cheat the firmware cable by getting this $7 cable instead of dropping $35 on the overpriced firmware update cable + shipping. Good news: the cable was actually working. Bad news: I had to hold the connectors directly to the J4 pins by hand and while it was just beginning the flashing screen I was trying to plug the battery and power back in as in the instructions, well the usb cable moved and became disconnected a moment. %&*^$#!!!
Now I have a panel that doesn’t appear to boot at all. I can’t get the firmware update software to show the “Are you sure you want to flash this panel…” dialog again. Not sure if I have a bricked device or I read some people saying if that dialog won’t come up again it is a bug and may have to try a different PC. Well I don’t have too many PCs lying around. I have the TS1 to maybe test the PC but now I am scared to brick that too.
Any ideas? I’d rather not lose the configuration. Is there a soft reset without being able to get into the toolbox (since the panel won’t turn on)? I found some hard reset instructions but they are pretty vague and didn’t seem to work (hold both home and services button and apply power to the panel). I can’t find any more troubleshooting instructions on the web without being a “dealer”. Any chance of getting this thing back from the dead?
On a separate note: If this doesn’t work, any panels out there that work better for smart homes and don’t require alarm.com, with possible cheap pro monitoring? I like some of the new stuff out there; Abode, ScoutAlarm, but they don’t have panels and we want to have cleaners, babysitters, etc be able to disarm with a scheduled code (but maybe integrate with IFTTT/Wink/SmartThings/Nest/Arlo too) and not be forced to use a smart phone for less technical users (grandparents).
That would be the reset procedure for a 2GIG Go!Control Panel. See video here. If you have a panel which does not respond to the update software and no longer boots up, unfortunately it is almost certainly bricked.
The most important thing I would bring up, for other readers as well, is that you should never try to use an alternate cable. Bricking the panel is extremely likely if you do. A bricked panel is unrecoverable. Always use the 2GIG Update Cable.
We are exclusively an Alarm.com services dealer. We do not currently monitor non-Alarm.com systems.
Alarm.com is probably your best bet for a mix of traditional alarm system capabilities and smarthome tech. A 2GIG panel with 345 mhz sensors for example will require much less maintenance and user involvement than a network of Z-wave sensors.
I would ultimately not recommend trying on the TS1, as it will likely result in a bricked TS1. Replacement Go!Control Panels can be found new and used. We only sell new equipment, and you can find the panel here.
