I’m still setting up my IQ4 NS panel, and have added a PG9929 4-button key fob.
Arming and disarming work fine.
But pressing the Panic (*) button (for 3 seconds) doesn’t work. The red key fob lamp lights up, and the key fob beeps, followed by the blue lamp above the disarm button. But no siren sounds. This is the same sequence of lamps and beeps that occurs if the disarm button is pressed when the system is already disarmed.
The key fob is set in Sensor Group “1-Mobile Intrusion”
“Police panic”, “Fire panic”, and “Auxiliary panic” are all enabled under Sirens and Alarms in the IQ installer app. Panel sirens is set to “All sirens on”. The siren works correctly if the system is armed and goes into alarm.
I can’t figure out whether I’ve misconfigured something or there’s a bug in the system.
On the Neo you can configure the onboard button parameters, and button functions can be set to disabled or to custom outputs, some of which would not be supported on the IQ Panel at this time. It would make sense if the button was sending a command for an unsupported feature for the LEDs to behave as you describe.
Ah, I did not recall this at first. I requested some info from Qolsys and by default the * key they say is only used for possible PGM output triggering.
The Panic function is performed by using button 5 (holding buttons 1 and 2 simultaneously) on a Qolsys panel.
