PECO TA-170 Thermostat
Hello, I recently moved into an apartment that has a Peco TA-170 thermostat which is MUCH different than thermostats that I previously used.
I used to set (approximate temperatures) the thermostat for Heat <70 and AC >70 with not activity between.
With the Peco TA-170 if you set the COOL temperature for 70 degrees and then set the high temperature, 70 degrees will ap[ear and if you change it to 76, the BOTH Heat and Cool will be 76 (or whatever temperature you choise but you can NOT choose 2 seperate temperatues.
My questions are, first I assume that there is no way of going around this to have TWO seperate temperature settings
And my secon question is, is there a way to RE-SET the thermostat to factory settings?
Bob
Surety is a DIY Alarm.com service provider. We do not provide support for the product you mention.
Supported devices are listed here.
