Can you please advise how to activate the Panic Alarm function from the app. Thank you!
Are you referring to a way to simulate a Panic button using the smartphone/tablet app? This is not an available function from the app.
Panic alerts would be tied to location. Typical usage of the app is outside of the home, and panic signals must originate from the panel (either by using the emergency button functions on the panel itself or an RF Panic button/keyfob with panic enabled.)
Are you instead referring to notifications sent to your App when a panic alert occurs?
Alarm.com implemented this recently:
https://www.alarm.com/about/press/PressGeneric.aspx?cmid=613
Do we have access to this?
Mostly just interested in the Panic function from the App.
Yes! In-App Panel Panic is available on request. Note that it requires Professional Monitoring to be activated.
We are working toward allowing users to enable/disable features like this through the System Manager, but that is not quite available yet.
Would you like me to go ahead and enable in-app panel panic for you now?
Yes.
Thanks … you guys are awesome!
Happy to help! In-App Panel Panic has been enabled for you. Might need to log out of the app and log back in to see it.
