I accidently programmed some code that seems to have locked me out installer / edit abilities.
Is there a very basic user / program manuel for the iQ4 panel?
Also confirm the most fast method of getting rpelies for you.
Default codes for the panel are:
Dealer 2222
Installer 1111
Master User 1234
Forgot your Dealer or Installer code but you have already connected your panel to Alarm.com? You can use the System Manager feature through your Surety login to change these codes remotely.
Under the My Alarm System tab, locate the Control My System section. There are a variety of remote options there, including options to change those codes.
Yes. A variety of guides can be nabbed from the panels product page. There is a user guide which is a bit easier to digest but te Installer Manual is going to be the most comprehensive. Links are towards the bottom of that page
Private Message, Forum Post, and email will all be the same speed and answered by the same pool of representatives. No need to double down on the same question via multiple methods… Questions are answered in the order they are received by representatives during normal business hours Monday through Friday 9:00 AM to 7:00 PM EST with limited availability on the weekends from 10 AM to 2 PM EST.
My motions do not seem to be working. What now ??
Looks like this was sent to us elsewhere and a representative has reached out. Please continue to follow up there if you have any questions about that issue.
