Trying to pair some IQ mini sensors with an IQ Panel 4 that’s already installed. The paper instructions with the sensor say to go “setting - installation” on the panel but im not seeing the “installation” option anywhere. A little help! Thank you.
To see the Installation option in the menu you’ll just need to enter the Installer Code when prompted as you are accessing settings.
If you use your master user code instead, you will not see the installation icon.
If you have forgotten your installer code you can reset it remotely in your system manager here with an active Surety subscription.
