I have a Vivint CP1 with no cell module. I have flashed 1.17 software to it. It will not let me add my zones as it says “Feature Unavailabe”. Would an active cell from your comany and some cell rest allow me to get to zone programming?
I just want to have local monitoring.
I also have a surveillance system connected to wi-fi. Is there any way to access this from my alarm system?
Also, if I ordered today when could I expect ti be online.
When connecting with an existing 2GIG panel, part of the initial connection to the system with our service is a series of commands to open programming, disable lockouts, and default the installer code for you. This does require connection to a suretyDIY Alarm.com account.
A non-Alarm.com IP Camera cannot be used with an Alarm.com account, and cameras do not connect in any way to 2GIG panels. In an Alarm.com account you can set recording rules based on sensor activity and alarms, etc.
For a stand-alone system you would be looking at minimal integration using the open collector output on the panel to trigger the surveillance system to record based on alarms if it has Input/Outputs. We would need to know specifics about the system/cameras to go further.
Well, you can purchase service at the same time as a module, and the account would be ready to go upon shipment, so as soon as you are able to install the module and run a cell test from the panel, you would be connected. All products ship from Columbus, Ohio.
