Hi, I’m a new subscriber, and trying to get my Interlogix NX-8V2 to connect to Alarm.com/surety. I ran the test (*[4][4]) which ran the siren, for 40 seconds, but I’m not seeing an update on the system manager page.
Recently purchased the house, and the previous owner did not know the installer code or previous operator (and I’ve verified it isn’t the default). He did say that they were using it with Alarm.com, so I’m hoping the cellular module settings are correct (Location 37 Segment 2 Bit 7)…although without the installer code I can’t verify.
I was prompted to create a login for alarm.com, and it looks like it’s communicating. Ran another test alarm for 40 seconds, it doesn’t show in alarm.com, but it’s showing other events (opening/closing doors, etc). It seems to have all the sensors, but the names aren’t there, I’m hoping that will populate over time?
How does it look on your side?
Once it’s in good shape, I’ll want to reset the installer code so I can document that for the future. Is there a way to request that once the system is enrolled?
Yes, it looks like the panel is signaling well now.
For many panel types, you can adjust the installer code in our system manager. This is not currently available for the NX. For the NX, send us a private message requesting the installer code change.
Alarm.com is still showing the sensors with generic name (e.g. " Contact (10) Opened/Closed"). Will that eventually be populated with the names in my local system, or should I go through and enter the names in Alarm.com?
